Chevrolet Avalanche
Platform: GMT 805 & 900
2011 Avalanche - Wheel Delamination
Old Apr 20, 2024 | 12:05 PM
toddrun's Avatar
Default 2011 Avalanche - Wheel Delamination
Hello All,
I have a 2011 Avalanche, I live in MN, so lots of winter road chemical, combined with the crimp on wheel weights, I have terrible clear-coat de-lamination on my wheels. One wheel is so bad, it continuously leaks pressure, I have to check it weekly, and top is off. Been looking at the option to have the refinished, powder coat painted, and aftermarket wheels or OE replacement wheels.
The issue I am finding is the 31mm offset on the wheels, hard to find aftermarket matching that offset. I put Michelin tires on recently, 13 ply, because I pull a heavy trailer occasionally and I found a great price. Problem is they were 275/65/18 instead of the stock 265/65/18, and on tight turns they do rub on my mud flats slightly. So, if I use an wheel with LESS offset than 31mm, it would make it rub worse and the wheel will stick out further. And finding a wheel with more offset is hard. Also, seems aftermarket wheels have a lower load rating.
Anyone run into this? Find any good aftermarket solutions? Or is OE replacement the best solution?
Thanks
Old Jul 11, 2024 | 1:18 PM
Crescent-Sal's Avatar
You can visit this site to get the best aftermarket wheels for your 2011 Avalanche.
Old Sep 6, 2024 | 6:32 AM
ChuckNorris's Avatar
בן זוגי ואני נשארנו דירות דיסקרטיות בעכו , וזו הייתה אחת ההחלטות הטובות ביותר בטיולים האחרונים שלנו! הפנים נוצר עבור פרטיות ורומנטיקה, הכל מחושב לפרטים הקטנים ביותר. התפאורה שיקית ומרגיעה, מושלמת לערב מיוחד. אם אתם רוצים חוויה בלתי נשכחת, זה בהחלט המקום בשבילכם.
MCF34
Dec 14, 2007 9:07 PM
LiveHuge
Aug 3, 2007 5:39 PM
dogger37
Dec 5, 2006 3:44 PM
