Chevrolet Avalanche
Platform: GMT 805 & 900
7 pin trailer braker outlet not working properly
Old Jul 28, 2020 | 10:15 PM
Chris Leier's Avatar
Default 7 pin trailer braker outlet not working properly
I have an 07 Avalanche, recently purchased a trailer, right signal light on the trailer not working. I used a wire tester and found out the one pin in my 7 pin receiver isn't working properly on the truck. The pin for the left signal light registers 12volts on the tester, the pin for the right signal light only registers about a volt. Are there any suggestions as to what I need to do to fix it? would a new 7 pin outlet fix the problem?
Old Jul 30, 2020 | 7:58 PM
dtcassist's Avatar
Former Sponsor
One quick check you can do is open up the wiring loom going into the outlet, find the wire that matches that pin and ***** through the insulation. If you have voltage there than its the outlet.
Can you tell if it's a factory installed trailer plug? If not, odds are there is a poor connection where they tapped into the vehicle harness.
Cta2885
Avalanche
Jun 21, 2014 8:25 AM
111toybox
Jan 28, 2014 1:49 PM
QuikHD
Nov 23, 2012 10:52 PM
jcbdelta1
Astro
Jul 8, 2010 8:57 PM
usandthem
Apr 5, 2010 11:43 AM
