Avalanche with tail light problem
I have a 2002 and the drivers side rear tail lights dont work, the brake lights work, the turn signal works and the fuse is fine. I have replaced the bulbs with the right replacement bulbs but still no lights. I am only reading 10 volts to the socket and the passanger side reads 13 volts. any suggestions as to what my problem is and how to make my lights work
sorry dude, i forget.. does the avalanche have circuit board by the taillights or separate socket? .. if it's circuit boards, try switching left to right..
also check for voltage at the socket but using a different ground and not the one in the socket, cause you could have a bad ground
4x4tx
August 20th, 2015 1:25 PM
beckya99
July 12th, 2011 12:29 PM
1LooseLugNut
August 15th, 2010 6:46 PM
jaymitchell01
October 27th, 2006 5:14 PM
