Chevrolet Avalanche
Platform: GMT 805 & 900
Avalanche with tail light problem
Old Apr 12, 2006 | 10:05 PM
tubby32's Avatar
Default Avalanche with tail light problem
I have a 2002 and the drivers side rear tail lights dont work, the brake lights work, the turn signal works and the fuse is fine. I have replaced the bulbs with the right replacement bulbs but still no lights. I am only reading 10 volts to the socket and the passanger side reads 13 volts. any suggestions as to what my problem is and how to make my lights work
Old Apr 24, 2006 | 6:47 PM
Nomad76lj's Avatar
Default RE: Avalanche with tail light problem
sounds like u may have to replace the socket on that side just make sure if u do it yourself that you make it watertight.
Old Jun 1, 2006 | 9:35 PM
viperjuice's Avatar
sorry dude, i forget.. does the avalanche have circuit board by the taillights or separate socket? .. if it's circuit boards, try switching left to right..
also check for voltage at the socket but using a different ground and not the one in the socket, cause you could have a bad ground
jefff1104
Apr 19, 2020 7:50 PM
4x4tx
Aug 20, 2015 1:25 PM
beckya99
Jul 12, 2011 12:29 PM
1LooseLugNut
Aug 15, 2010 6:46 PM
jaymitchell01
Oct 27, 2006 5:14 PM
