I have a 2003 Avalanche where the passenger side blend door actuator has gone bad. It has the dual zone automatic front climate control with the rear center console vents. Attached is a picture of the build codes list, what is the part number for the correct actuator so I can order a replacement?
Thanks in advance,
Rob in sunny Az
Thank you! All the listings I had been seeing had comments of "except CJ2" or "except D07", since I had both codes I couldn't figure out which one was the overriding one.
Now to order and install it, fortunately I have found several videos on the process.
