Chevrolet Avalanche
Platform: GMT 805 & 900
Brake issue 2004 Chevrolet Avalanche
Old Dec 6, 2020 | 4:03 PM
Jimjohnson2002's Avatar
Default Brake issue 2004 Chevrolet Avalanche
This is my first issue where I wanted to reach out for help as I am a really mechanical person. I have a 2004 Chevrolet Avalanche with Hydra Boost brakes. I replaced the brake booster, Master Cylinder, all 4 calipers, all four rotor and brakes. I have did a brake line test no leaks. I have bleed all the brake lines and even bleed the power boost and yet my brake petal goes to the floor when engine is turned over. Any suggestions on what my next step should be. Getting very frustrated right now and you would be my wife’s hero if you could help me fix this issue. Thanks Jimmie
Old Dec 6, 2020 | 4:25 PM
kevinkpk's Avatar
My take, did you bench bleed the MC? you still have air in the lines. Double check the line fittings to make sure you have closed all the bleed valves.
Old Dec 7, 2020 | 7:47 AM
hanky's Avatar
There s an accumulator on the hydroboost unit, , It may not be doing its job.
Rooty
Avalanche
Jan 16, 2018 12:29 PM
curtisj8
Avalanche
18
May 8, 2015 6:18 AM
bluerado04
Nov 10, 2014 12:09 PM
Jfandrich
Feb 28, 2011 10:31 AM
