Chevrolet Avalanche
Platform: GMT 805 & 900
brake issues 2004 avalanche
Old Dec 18, 2011 | 9:30 AM
  #11
curtisj8's Avatar
Originally Posted by EinST
It sounds like a sticking isolation valve (part of the BPMV) which is normally open when the ABS is not active. Consider taking it in for service. You need a scan tool to diagnose the 2004 properly. I've been told that especially the BPMV is nothing to fool with.
appointment is made. see what happens now i guess thanks people
Old Jan 7, 2012 | 2:33 AM
  #12
curtisj8's Avatar
just a recap on the brake issue. think i found the problem. the guy that had the truck before me must of been a ****ing moron and used power steering fluid instead of brake fluid and it looks like it ****ed over the whole system. so i guess the new question is has anyone ever came across this before and is there an easy fix other then rebuilting the whole brake system. i really dont want to have to sell the first born to pay for it all lol
Old Jan 7, 2012 | 9:29 AM
  #13
EinST's Avatar
Oh, that's some tough luck. Some sort of a vandalism comes to mind (crazy ex?). Hopefully another member has an idea, even where to start with something like that.
Old Jan 18, 2012 | 1:17 AM
  #14
curtisj8's Avatar
so far just changed the master cylinder and it seems to be fine. hope it stays that way
Old Jan 18, 2012 | 11:17 AM
  #15
EinST's Avatar
Thanks for the update. Keeping my fingers crossed.
Old Mar 27, 2012 | 11:14 PM
  #16
Forge04's Avatar
I'm hopin for you as well. Hopefully change out fluid and yeah the master cylinder. As long as you don't have leaks at the calipers you're good there.
Keep us '04 owners updated
Old Jun 29, 2012 | 3:01 PM
  #17
spyncycle's Avatar
Back in the mid 70's a guy I worked with put power steering fluid in his brake system. It ended up eating up every rubber seal. If it were me, I would replace all calipers and the master cylinder.
Old Jul 6, 2012 | 10:41 AM
  #18
spyncycle's Avatar
Originally Posted by curtisj8
ok so heres the latest. went to change the front brake pads. when i went to compress the caliber it wouldnt move at all. not even enough to be able to remove it. i had to release the pressure from the bleeder screw. so is that a slave cylinder issue or something else. would it be possible that would be my problem all along. would thought cause the rest to slowly come on some how
That can be caused by a defective rubber brake line, that connects to the caliper. I saw it happen on a Ford Ranger once.
Old May 8, 2015 | 6:18 AM
  #19
BillBreeze's Avatar
Default Would appreciate follow-up on brake issue
Hi,
I know that this thread is old, and I've posted only once before to this forum, but I'm having problems with a 2005 GMC Jimmy with much the same problem. The brakes come on while driving. It seems to be all four as the vehicle does not pull to either side. Took it to a GM dealer yesterday they said that the brake fluid was possibly contaminated and that everything with any rubber on it in the brake system would have to be replaced. I bought the vehicle just three weeks ago (it has a month's warranty) and the problem is intermittent. Did replacing the master cylinder and calipers correct your problem? Thanks!
TheRaptor
Sep 26, 2021 9:19 AM
Slobby Baymon
Nov 12, 2013 11:52 PM
734 Jack
Avalanche
Aug 10, 2010 9:55 AM
wingerak92
Avalanche
Apr 7, 2009 12:36 AM
Chuckus95
Avalanche
May 2, 2008 10:03 AM
