Chevrolet Avalanche
Platform: GMT 805 & 900
Help!!!
Old Nov 29, 2012 | 8:18 PM
tahoeman's Avatar
Default Help!!!
O.K...So my transmission went out a few weeks ago at 65,000 miles. Ouch! However, my check engine light came on today and now my car stays in V8 mode. Could this be related to the transmission rebuild? Also, for the first time ever...I had maybe put 25 miles on the car since the rebuild and headed to the store. I came out and tried to start the car but the car just cranked and wouldn't start. I cycled the key and it fired right up...Do I have some gremlins or did the company that did my trans rebuild screw something up! Did they not reset some codes or something?
Thanks
Bill
Old Nov 30, 2012 | 11:36 AM
Do you need to cycle the key twice every time to start? If so it could be the fuel pump check valve going bad. You would have to check your fuel pressure when trying to start after sitting for a while.
Old Nov 30, 2012 | 12:23 PM
tahoeman's Avatar
It only happened one time...
Old Dec 1, 2012 | 10:22 AM
As long as it only happened once, there is nothing to worry about. If it starts to happen more frequently, that is a sign of problems to come.
Old Dec 3, 2012 | 7:57 AM
Official GM Rep
Thanks
Bill
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> tahoeman,
I’m sorry you are experiencing this issue with your vehicle. I would be happy to check my resources for any known issues based on your description. If you would like me to proceed, please PM me your VIN.
Louis
GM Customer Service
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
