Chevrolet Avalanche
Platform: GMT 805 & 900
Help with "SERVICE 4WD"
Old May 28, 2013 | 12:50 AM
pabst_20's Avatar
Default Help with "SERVICE 4WD"
I have a problem with my 2004 chevy avalanche. When I push the 4high the transfer case locks in and everything but my actuator on the front axle won't extend out same thing in 4 low it will shift to low gear just no 4 wheel drive. The light on the two wheel drive button stays lit up but whatever other button u push just flashes while the 2 wheel drive light stays on solid. I took the actuator off and put it on my dads truck and it works fine on his. I got under the truck and in two wheel drive u can turn the front drive shaft like normal and when u shift to 4wd it locks in like its supposed to so u can't turn it by hand. Transfer case is doing everything normal but just have a problem somewhere that won't let that actuator extend out to lock in the front axle. Has anyone else had this problem and can someone tell me what I need to fix it. Does the same thing in auto 4wd and the message center just says SERVICE 4WD. Thanks for any info anyone can provide.
paintballhead03
Dec 30, 2020 12:20 PM
D Chevy
Sep 17, 2012 12:06 PM
Skybuster1
Feb 24, 2012 10:40 AM
aeleggettIV
Apr 6, 2010 12:14 PM
mike688
Uplander
Jan 25, 2010 12:16 PM
