Chevrolet Avalanche
Platform: GMT 805 & 900
Low oil pressure light is on
Old Jul 16, 2021 | 8:59 AM
CJsluck's Avatar
Default Low oil pressure light is on
I have a 2011 Chevy avalanche. I had to disconnect my battery for a period of time so I could replace a camshaft postion sensor. When I started truck up the low oil pressure light was on. Checked the oil it is fine.
Not thinking its the sensor or the oil pump we replaced those spring of 2020.
My question is,is there a reset I need to do or what could be other possibilities?
Old Jul 16, 2021 | 10:29 AM
hanky's Avatar
Usually the first thing to come to mind , RECHECK your work.
Then make sure the wire from the oil pressure sending unit did not get pinched somewhere during the time work was done.
If the wire from the sending unit gets grounded , it can cause the light to illuminate..
Old Jul 17, 2021 | 11:33 AM
bearbait's Avatar
When you changed sensor did you by any chance also clean the screen filter under the sensor?
Old Jul 18, 2021 | 10:24 AM
ssevanmike's Avatar
I think you can try disconnecting the battery again, wait 30 minutes then reconnect to see if the light still comes on
44fore
Jul 1, 2019 12:48 AM
Ssomave1961
May 9, 2018 2:10 PM
jwe
Jun 1, 2014 7:18 PM
ruthie73
Jan 24, 2012 5:31 PM
101btp
Nov 30, 2010 8:36 PM
