Chevrolet Avalanche
Platform: GMT 805 & 900
rear differential overheating
Old Aug 5, 2012 | 3:05 PM
avalanche guy's Avatar
Default rear differential overheating
while towing a 24 ft trailer in tow mode w/distributing hitch the truck smoked the rear axle. no fluid was ever lost. it was on a 175 mile trip. we have now replacind all the bearings in the rear axle and has a slight whine. i did go to royal purple oil 75w syn. anybody had similar issues and what can i do to stop it in future other than monitor temps?? shop said didnt know cause but possibly a pinion bearing going bad.. never any indication of a problem until i smelled 90 w oil on trip. haven't towed anything yet but temps seem to staedy around 140-180deg
Old Aug 25, 2012 | 10:57 AM
cleveland63b's Avatar
which bearings did you replace and how do you know it was "smoked" if no fluid was lost?
Old Aug 27, 2012 | 7:38 AM
Replaced axle and pinion bearings--the rear axle was so hot you couldn't touch it for awhile, and the 90 w oil smell was so bad you could smell it from 15-20 ft away from the vehicle. The tech says it was full of fluid but very burnt. NEVER GAVE US ANY WARNING SIGNS OF A PROBLEM(NOISES,SMELLS,LEAKS). CHEVY DECLINED ANY ASSISTANCE BECAUSE IT WAS 21 DAYS OUT OF WARRANTY WITH 74 K ON VEHICLE. VERY DISAPPOINTED..
Old Aug 27, 2012 | 11:46 AM
you had a bearing failure; bad bearings run hot.
As long as its set up properly and the fluid is changed when required; you should be ok. You just got a bad part.
...and the weight of your trailer is?
Old Aug 29, 2012 | 1:12 PM
Trailer weight is 3900 lbs. I would have thought it would have made some noise beforehand? Should i be concerned if when towing it reaches temps of 200 or close ? I have a infared temp gun i'm using to check it periodically.
Seagrave7
Aug 24, 2009 11:55 PM
tendota24
Oct 21, 2008 1:16 PM
keebeaux
Aug 26, 2007 8:26 PM
sm3earl
10
Feb 14, 2007 12:31 AM
jordanhaskins
Nov 7, 2006 2:33 AM
