Rear End Cover
Changed the rear end cover on our 04 Avalanche and the aftermarket one we got from Napa only holds 2 liters of oil whereas the original one held 2 1/2 liters. The question is, would the 2 l. be enough?
don't overfill it or there is a small chance it could create seal leaks. the 2 liters will be fine but you will require a shorter change interval. most peple change to aftermarket covers that allow a larger volume and provide heat sinks.
