Chevrolet Avalanche
Platform: GMT 805 & 900
When idle rpm stays high for a bit (2012)
Old Jul 27, 2024 | 3:11 PM
dejongmc's Avatar
Default When idle rpm stays high for a bit (2012)
Issue is that when in Park, and I hit the gas pedal the rpm goes up as expected, but when I release the gas pedal the rpm's stays up for 2 to 3 seconds before it slowly goes back to normal idle.
I already replaced the throttle body, gas pedal, and purge valve, but issue remains.
There are no codes.
Any idea what else I need to look at?
Old Aug 7, 2024 | 4:47 PM
Bud Wilkinson's Avatar
Default 2011 Avalanche 5.3 L, High Idle
Hello,
I am having the same issue. Cleaned old Throttle Body, Then replaced it with a new part. Was looking for the IAC valve but I can't t find it anywhere and suspect the ECM uses the Throttle to accomplish the same thing.
Did you find a resolution?
There are no codes.
Old Aug 7, 2024 | 9:25 PM
dejongmc's Avatar
Eventually I brought my car to the shop and told them that I replaced the throttle body and gas pedal (which has a sensor too) with new ACDelco parts, but the issue is still there.
I even tried the 'relearn' procedure but that didn't fix it either.
So they calibrated the new throttle body and gas pedal with the ECU and all is working fine now. Cost was $165 which was not bad in my opinion.
Brownie289
16
May 31, 2024 5:03 AM
Avalancher2008
Avalanche
Feb 7, 2024 7:53 AM
red suburban
May 6, 2023 12:52 PM
wino454
Aug 10, 2014 8:41 PM
Josh R
Sep 1, 2008 11:12 AM
