Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
2.2 95 Corsica Oil Leak
Old Dec 30, 2006 | 9:10 PM
raysrestoration's Avatar
Default 2.2 95 Corsica Oil Leak
223 K , 95 2.2 Corsica. Changed plugs about a month ago, no oil on plugs. Last 1400 K in 3 days of driving, had to fill up oil twice(so approximately 8 Litres)
I have placed cardboard under the car, no spots while parked. Will get car to operating temperature and test for idle leak.
Looking for some advice on best place to start looking.
Thanks
Ray
Old Jan 4, 2007 | 2:05 AM
kcb37's Avatar
Default RE: 2.2 95 Corsica Oil Leak
Do you have any oil in your coolant? If so you probably have a bad head gasket. If not does your car smoke. It should be blue if it is oil. If your piston rings are bad you may be burning oil, while the plugs foul very slowly.
Old Jan 4, 2007 | 11:09 PM
kcb37 thanks the note. The rad resevoir on this car is veryshallow at the cap location, and the FULL COLD line on the deep end of the reslines up to tiny amount of coolant in the caparea. The coolant is still nice and green and I not certain how to confirm if there is oil in it.
The car does not smoke.
Thanks
Ray
Eric Sherden
Sep 24, 2013 1:21 PM
CKFords
Cobalt
Jun 7, 2010 7:30 PM
CKFords
Jun 6, 2010 11:58 AM
brock1912
Feb 23, 2009 2:50 AM
trush
Jan 1, 2008 9:27 PM
