Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
88 beretta 2.0L i4 wont start
Old Oct 26, 2011 | 2:26 PM
beretta8820's Avatar
Default 88 beretta 2.0L i4 wont start
trying to ressurect 1988 beretta with a 2.0L i4. have dropped/cleaned fuel tank, replaced entire fuel pump assembly, replaced spark plugs, ignition coils, and wires, oil pressure sensor, cleaned out throttle reservoir and injector, no fuel or spark problems whatsoever, no compression problems, car will virtually crank but will not run. have tryed everything.
any suggestions or tips???
Old Oct 26, 2011 | 5:20 PM
could this have anything to do with the ignition module? does this tend to go out with time?
Old Dec 23, 2011 | 9:32 AM
unbelievableny's Avatar
Default Beertta problems>
Where are u located maybe i can u outi
Old Dec 23, 2012 | 2:59 PM
GHOSTOWLGRID's Avatar
Are you sure there is no fuel or spark problems?
I know these cars had a water leak, maybe the ECM is not turning on?
Do you get a valid signal from the CPS?
Are you sure there is not a bad injector? if one goes, they all get shut off by the ECM to protect itself.
Bad coil?
Something is not working if it cranks and won't start.
Maybe its too rich?
Check the CPS, many times if that is bad, the engine will not run at all...
any more info will help.
sleepingciv
Jul 25, 2020 1:03 PM
Rz3z26beretta
Apr 27, 2015 6:02 AM
wildboy74ss
Apr 1, 2009 5:10 PM
JohnC
Dec 23, 2008 11:32 AM
mcfarlinc82
Dec 12, 2007 11:43 AM
