Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
'90 Chevy Lumina 3.1 crank/no start when warm
Old Sep 8, 2015 | 9:57 PM
GMCotech2's Avatar
Default '90 Chevy Lumina 3.1 crank/no start when warm
When the engine reaches operating temperature and is intentionally turned off it will not start up again. On a cold start, the car will crank, start, and drive normally. The car will operate normally even after reaching operating temperature. The problem only occurs after turning the car off. I have good fuel pressure (approx 40 psi) cranking and running. I have even done an injector drop test to insure injectors are actually operating individually. I have good spark. I have attached the computer and I have RPM during cranking (crank sensor test). Has new MAP sensor. Any ideas???
GMCotech2
Jan 14, 2017 11:21 PM
gthatsme
Jul 23, 2015 12:59 AM
calbyd
Jul 19, 2015 10:09 PM
zrafferty
May 4, 2015 10:02 AM
RobotRick
Mar 15, 2014 10:53 AM
