Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
90 Lumina 3.1 auto dies at idle
Old May 25, 2011 | 6:14 PM
Jonathan Rader's Avatar
Default 90 Lumina 3.1 auto dies at idle
I have a 90 Lumina 3.1l 4speed auto trans it dies at idle and sometimes when I come to a stop. I suspect either the Iac or the egr but I don't know how to test either since the egr is electric and not vacuum. It hasn't coded for anything so that was no help. I am stumped any help is appreciated thanks.
Old Apr 11, 2014 | 7:01 PM
dioda's Avatar
Default 91corsica
my 91 corsica hesitates upon acceleration, bucks, ect. and often dies at stops, have replaced the oxgen sensor , the iac, and the throttle position sensor, and still doing it, have found 2 vacum leaks and fix , the code scanner at the parts store still reads, bad oxigen sensor , bad tps, and cam sensor , any suggestions?
Old Apr 11, 2014 | 9:38 PM
mikeatpriestlake's Avatar
Default lumina dies
you can go to easy auto diagnostics .com and get procedures for testing the electrical parts, but I can tell you that I had similar problems with a 91 lumina 3.1 and the problem ended up being the injectors. you have to remove the plenum to test them, but after replacing a whole bunch of parts, it ended up being bad electrical portions of the injectors. Its a pain to get to them because of removing the plenum but after you pull your hair out trying all the other parts, go there and see what ya find.
zack3439
Camaro
14
Jul 28, 2015 7:25 AM
copterdoc
Oct 23, 2010 12:20 PM
mjshealy
Dec 29, 2009 6:54 PM
h1gh0ctane
Jan 7, 2008 1:29 PM
h1gh0ctane
Jan 5, 2008 12:05 PM
