Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
93 Lumina euro - Help With Studs!
Old Jan 25, 2013 | 4:13 PM
wardpipe's Avatar
Exclamation 93 Lumina euro - Help With Studs!
I just need to know if I have to REPLACE the hub to change the (front) studs?
Driving on Saturday and ALL the studs on the front right side sheared off and my wheel shot off! awesome!
put on replacement studs and they are barely long enough to get the lugs on and we had to FORCE them into the hub. I know we need longer studs. can i just take the hub off then put it back on? i'm worried its gonna fall apart or something.
Old Jan 25, 2013 | 9:39 PM
Check Rockauto, the have studs that are 34.5 millimeters long and also 41.5 mm long. I don't know if 7mm will make the long enough or not. The studs are supposed to be pressed in so that they don't come out on their own when the lug nuts are off.
Old Jan 26, 2013 | 1:16 PM
wardpipe's Avatar
Question
I know i need the longer studs. i just need to know if i need to REPLACE the hub. I've never removed a hub before but i'm mechanically inclined and i have help.
Old Jan 26, 2013 | 1:56 PM
kevinkpk's Avatar
I don't know what it looks like. However you will have to remove the hub/rotor if you cannot access the backside of them. I just take a hacksaw, cut them flush with the rotor surface, then punch them out. Install insert the stud from the backside, screw on lug nut. With a 4 way tighten the nut to pull the stud all the way in.
Shadetree63
Jun 22, 2015 2:57 PM
farr52
Oct 13, 2010 1:46 PM
gianelli280
Sep 28, 2009 10:58 PM
Blazerpaul89
K5 Blazer
Sep 12, 2008 10:25 AM
