Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
93 Lumina rear noise..
Old Sep 9, 2006 | 2:46 AM
jayno20's Avatar
Default 93 Lumina rear noise..
just got this car and there is a noise coming from what i think is the drivers side rear that sounds like a rubbing or a squeaking. Maybe the strut bushings i thought, but anyone ever have this problem to know exactly what it is?
Old Sep 9, 2006 | 9:47 AM
Nomad76lj's Avatar
Default RE: 93 Lumina rear noise..
it my be a tire rubbing or your brake draging a bit. try jacking the car up and see if you can roll the tire easly if you cant it is likely your brake. hope this helps.
Old Sep 9, 2006 | 10:20 PM
jayno20's Avatar
it only seems to happen when the car moves up or down so i am thinking something with the strut... would the brake rubbing have the same symptoms?
Old Sep 10, 2006 | 12:24 AM
kcb37's Avatar
Does it do it when you hit the bake or stop when you hit the brake?
If it does it when you just drive around corners and bumps so on and so forth check you complete suppension, probalbly could use all new bushings. It may be shocks/struts, but it sound to me like a bad bushing somewhere in the suppension.
Old Sep 10, 2006 | 5:43 AM
jayno20's Avatar
no it doesnt do it when i hit the brakes... what would i look for to see if its a bad bushing?
Old Sep 10, 2006 | 6:17 PM
kcb37's Avatar
most of the time they will be brittle and crakced, if the struts are old it wouldn't hurt to replace them, but it could be the springs or something like that too.
Old Sep 11, 2006 | 5:26 AM
jayno20's Avatar
if i push down on the rear end it makes a noise, not the same one as i hear when driving, but its still a squeak.. does that sound like struts or bushings?
Old Sep 11, 2006 | 11:33 AM
kcb37's Avatar
I couldn't tell you. It is hard to tell even when you are at the car, but if you can have someone push the car down (if you have room) and listen for it, that would be about the best way to find it.
That could be your springs too.
Jim Spahr
Jul 31, 2012 8:28 PM
RomanGuzi
Oct 2, 2011 11:40 AM
GTSVip9
May 29, 2009 12:44 PM
ladagosta
Feb 28, 2009 2:45 PM
MagicElectric
Feb 27, 2007 3:42 PM
