Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
corsica dies after startup
Old Jun 9, 2013 | 11:28 PM
oldtruckluvr's Avatar
Default corsica dies after startup
i have a 91 corsica with 3.1... 2 days ago all was fine. now it dies after startup or if you hit gas to floor. fuel pump has 40psi constantly. new iac valve, new plugs and ignition control module. not throwing any trouble codes either. tps is working, i checked that. any ideas? thanks
Old Jun 10, 2013 | 7:28 AM
Jeff Collision's Avatar
It sounds like a crankshaft sensor or an ignition module problem. There are two crank shaft sensors on this engine. One is behind the crankshaft pulley, and another one is on the back of the engine. It has two wires that hook up to the ignition module. Check that wire, make sure it's no touching the exhaust or plug wires. As for the ignition module, it is under the ignition coils. There is no test to perform on that other than trial and error. Check that wire running to it.
Old Jun 10, 2013 | 9:18 AM
thank you for the reply. i installed a new ignition control module about a week ago. ran fine after installation. i will check to make sure no wires on exhaust. hope to figure this out.. car has been nothing but problems for me!!!
Old Jul 10, 2013 | 9:20 PM
jsperk's Avatar
I just chased a stalling problem on my 3.1 98 lumina. Found the crank sensor wires pinched in exhaust manifold and copper wires exposed. Pulled them out and taped them up. All seems good.
Had it to three shops no one could find the problem. I ended up seeing a pic online somewhere showing the wires that get caught. I paid for a few p[arts that I didn't need.
zack3439
Camaro
14
Jul 28, 2015 7:25 AM
General23cmp
Sep 17, 2013 9:51 PM
oldtruckluvr
Sep 4, 2013 8:15 PM
mdisco77
10
Aug 4, 2013 6:32 PM
TRock
Feb 19, 2006 7:44 PM
