Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Lifter noise when cold, how do I fix
Old Jan 30, 2008 | 8:54 AM
ljclumina's Avatar
Default Lifter noise when cold, how do I fix
Just purchased a 1996 lumina with 14,800 miles, verified with tittle search, yep a little old ladies car that only went on the road on Sunday. Changed oil and filter with 5-30 and lifters make noise when cold, goes away reaching normal temperature. Engine is 3.1 (3100), any suggestions. Thanks in advance
Old Mar 7, 2008 | 3:13 PM
greysvo's Avatar
Default RE: Lifter noise when cold, how do I fix
This is likely to be piston slap versus lifter issue, which is a well known issue with the 3.1 engine. I use 1 quart of Lucas Oil and 4 quarts of 5w20. Seems to help, and my car has over 168K miles on it, and runs strong. Makes a racket at start-up though! Embarrassing! But quiets to a purr after running for a while...
Old Mar 7, 2008 | 4:34 PM
EvansBlue's Avatar
Probably is. For a permanent fix, it'll take a rebuid and replacement of all 6 cylinders plus honing the cylinder walls.
Old Mar 17, 2008 | 6:40 AM
PrairieBoy's Avatar
I have a 96 Lumina with a noisy lifter. The famous like a knock Chevys didn't start until 99 I think. It is possible that it is piston slap but you need to take it to a garage to have someone listen to it to determine the correct problem. You should geta coupleopinions from professional mechanics.
chevyman108
May 25, 2017 3:25 PM
ddog96mn
Aug 9, 2012 6:52 PM
Wartrace
May 27, 2012 8:48 AM
thejumpsuitman
Sep 13, 2010 4:25 PM
shayandude
Apr 8, 2009 5:23 AM
