Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Trans wont shift into OD untill warm
Old Apr 11, 2012 | 11:16 PM
Kipp88's Avatar
Default Trans wont shift into OD untill warm
I'm curious if this is normal or not. I've got the 4 speed transmission on my 93 chevy lumina. And when cold the car only shifts into the first 3 gears. And won't go into OD no matter my speed. But after I've been driving it and it getting warm, then it wants to shift into OD. After it gets hot, the trans shifts completely fine.
Is this normal? If not would anyone know what could be going bad?
Old Apr 12, 2012 | 11:09 AM
EinST's Avatar
If it's just the first couple of minutes, accompanied by higher RPM shift points but without noticeable slippage, it's nothing to be concerned. It's to let the engine warm up quicker and thus reduce emissions.
Old Apr 15, 2012 | 9:59 PM
Kipp88's Avatar
ah okay thank you. the only thing that bothers me is when im going about 55+ and the trans is in OD. it seems as if i dont press the gas enough, it will shift into 3rd. then ill have to step on the gas a little harder for it to go back into OD. is that normal? i dont mean to sound picky, but i guess i am picky about getting my car completely back to normal lol.
Old Apr 16, 2012 | 12:35 PM
EinST's Avatar
I don't understand what you're trying to describe and thus I can't comment on that. If you really want peace of mind, you'll have to take it to a transmission shop.
Old Dec 23, 2012 | 2:42 PM
GHOSTOWLGRID's Avatar
Oh....
You have a 1993 Chevrolet Lumina.
You have a 3 speed auto, you do not have a 4 speed transmission.
You do not have overdrive, you have only 3 gears then a torque lock up.
What your worried about is the TCC lock up
(Torque converter)
The torque converter will not engage until the vehicle gets up to temp.
The torque converter will not engage above a certain speed, usually 37 MPH.
The torque converter will disengage if you let off the gas, press the break, or push to much gas.
The torque converter only locks up after 3rd gear.
Your selector reads: P-R-N-D-2-1
This is perfectly normal operation for your vehicle, keep a steady foot and it will stay locked up longer...
I hope this helps.
Your car is one of these:
1993 Chevrolet Lumina Base Sedan 2.2L 4-cyl. 3-speed Automatic Features and Specs
You do not have this, but I post it anyways for helpful info:
The 4 speed auto has overdrive.
The 4 speed auto also has a torque converter.
The 4 speed auto selector reads: P-R-OD-D-L
L is first and second gears in direct lock up with the TCC, only shifts at max engine RPM.
OD goes 1-2-3-4 then will lock up.
D goes 1-2-3 then will lock up.
OR it will read: P-R-N-D-3-2-1
D is 1-2-3-4 Then lock up.
3 is 1-2-3 then lock up.
2 is 1-2 then no lock up.
1 is just 1 with no lock up.
Old Jan 19, 2021 | 7:58 PM
jeffery brewer's Avatar
Originally Posted by GHOSTOWLGRID
Oh....
(Torque converter)
I hope this helps.
your wrong my 97 lumina has P.R.N.OD.D.2.1
Old Jan 19, 2021 | 8:42 PM
#1 - You just resurrected a 9 year old post.
#2 - he was talking about a '93. You have a '97.
Old Aug 15, 2022 | 6:36 AM
graigabrey's Avatar
Hi there, myraus. How’s it going now? I hope you’ve solved your issue. Tbh, I’m curious about how you’ve solved it.
Sctmcly
Nov 5, 2023 6:51 AM
Bruce Flesher
Aug 29, 2017 6:13 AM
rwolfgram10
Nov 23, 2014 8:08 AM
77k10
11
Mar 1, 2010 5:27 PM
ricebean
Nov 2, 2009 1:59 PM
