2000 Blazer 4x4 issue
Hello all,
Attempting to diagnose a 4x4 related noise I have, looking for some guidance. It's pretty straight forward, when I engage the 4x4, everything is fine and there's no noise, but when I turn in either direction there's a loud clunking noise, and then when I go back straight it goes away. Doesn't matter if I'm on gravel or pavement, it's the same. One weird thing I've noticed is that it doesn't always go away when I get back into 2WD, sometimes it takes a few miles or even a few days to go away, but it does always eventually go away when I'm back in 2WD. Any information is greatly appreciated.
Thanks,
Dustin
Thanks,
Dustin
Hello all,
Thanks,
Dustin
Thanks,
Dustin
Have you used the "back the hell out of it", treatment? You just keep backing up in 2WD and stomp on the brakes HARD in gear. Otherwise, it is a likely a TCM or 4WD actuator issue, most likely. Wish we still had solid linkage to the TC from the floor mounted lever like my 241 does.
The noise when turning sounds like it would be a front differential issue to me. Sometimes the front axle stays engaged even when the transfer case is disengaged but the front wheels drive the gears anyway.
Do the shavings test and look for metal in the oil by draining some out.
