Blazer Combining style with comfort, this all-new, sporty SUV is the epitome of adventure.
Chevrolet Blazer
Platform: C1XX
92 Full-size Blazer.. 5.7 350 rough start and backfire
Old Aug 8, 2020 | 4:54 PM
royposey96's Avatar
Default 92 Full-size Blazer.. 5.7 350 rough start and backfire
ok… I have a 92 Full size Blazer, 5.7 350. My son and I are rebuilding it and have replaced the motor with a crate engine from Summit. Obviously new wires, plugs, distributor and cap. Rebuilt injection system and new injectors.
ISSUE: When we turn it over it acts like it wants to start REALLY ROUGH and then back fires through throttle body. I know it has to be a timing issue… Could I have missed something when installing distributor? Is the timing just that far off? We put distributor on before we stabbed motor, set at top dead center on #1, i turned the cam gear to install distributor to line up number 1 cylinder (or i felt really close), I have checked all wires and tested spugs at distributor and have a spark on all. At a loss, any ideas would be appreciated!
Thanks, Roy
Old Aug 8, 2020 | 5:24 PM
kevinkpk's Avatar
Thanks, Roy
Go back to the simple things, is the plug wires correct for rotation? Is number 1 cylinder at tdc compression?
Old Aug 8, 2020 | 8:36 PM
royposey96's Avatar
Yes sir on the wires order, pulled all wires and rerouted when I checked for spark. Will reinstall distributor at top dead again to verify that tomorrow. Thank you and if you think of anything else I appreciate the assist.
Old Aug 28, 2021 | 1:19 PM
chevyboy@22's Avatar
OPTIONSSTEP 1: CHECK ENGINE LIGHT
Anytime you have an engine that is backfiring the first thing to look for is a check engine light. If no warning lights are on continue down this guide. If the check engine or service engine soon light in on scan the computer for trouble codes. This will help locate the system that is having a problem and needs repair.
STEP 2: CHECKING FUEL SYSTEM PRESSURE
An intake back-fire explosion can be caused by the fuel air mixture being to lean when the engine is demanding power. Every internal combustion engine runs on a mixture of 14 to 1 which is fourteen parts air to one part fuel. Proper fuel pressure is needed to atomize the fuel correctly when it leaves the fuel injector to complete the burn process.
The most common cause for this problem is a weak fuel pump which cannot supply the volume of fuel needed for the injectors to produce a proper spray pattern or deliver the amount of fuel needed for engine acceleration. The fuel system pressure must be tested to see if the fuel delivery system is the problem.
Bugfuel
Jan 27, 2015 10:45 AM
OldManBob
Jul 26, 2013 3:21 PM
meetmonk
Mar 13, 2012 11:00 PM
nashcarjay
Mar 11, 2012 5:42 PM
arrowhead1
Dec 14, 2008 8:20 AM
