Blazer Combining style with comfort, this all-new, sporty SUV is the epitome of adventure.
Chevrolet Blazer
Platform: C1XX
Throttle problem
Old Aug 6, 2019 | 12:24 PM
Thomasmatt's Avatar
Default Throttle problem
About 2 weeks ago, I was driving and set the cruise control on my 2000 Blazer with the 4.3 V6 in it and when I went to kick the cruise off, the idle stayed high. And it still is high and it makes braking difficult so I have to throw it in neutral to come to a stop and when I do the RPMs go to about 1300 and when moving putting it in neutral takes the RPM to about 2100. I disconnected the battery overnight and it didn’t resolve the issue!! Any info would be appreciated
Old Aug 6, 2019 | 1:25 PM
kevinkpk's Avatar
Disconnect the cable, start it, what's the rpm at that point? Might be a mechanical issue
Old Aug 6, 2019 | 1:41 PM
Thomasmatt's Avatar
I don’t know if it’s a sensor issue or mechanical and I haven’t gone to my mechanic yet to plug in diagnostic
Old Aug 6, 2019 | 1:44 PM
kevinkpk's Avatar
That's why I suggested unhook the cable, you will need to determine which one. If it has a TPS, that should not cause your issue. This started after using the cruise. With the cable unhook, make sure it can move and not binding. Probably is electrical. If the TPS is out of position from what the ecm is requesting, that however could do it.
Old Aug 6, 2019 | 2:08 PM
Thomasmatt's Avatar
Figured it out. That’s what it was. Thanks for your help
Old Nov 14, 2019 | 4:03 PM
Leon papa's Avatar
I have a 2001 blazer with V6 vortex engine, and it has a problem, the engine accelerate itself and when I leave my foot from the accelerator it is still accelerated
Please need help
