1999 GMC Sub and 94 Chevy Camaro Engine Swap?
I got to thinking here... I've got a 1999 GMC Suburban with a 5.7 V8 350... and i want to swap that engine out and put it in my 94 Camaro witch currently has a V6 3.4 207.... Could I swap out the engines in these applictionsand transmissions?
I'm sure its possible,some things to think about,oil pan from your burb might not fit in the car,you will need theengine wire harness and computer from the burb,also not sure how that wire harness from the burb will mate up with your car harness.There might also be some differences in transmissions between the burb and the car,you might want to check interchangability on those as well as the drive shaft.Definately a project...good luck!
