2016 Camaro
Platform: F-Body & Zeta.
1999 GMC Sub and 94 Chevy Camaro Engine Swap?
Old Oct 21, 2008 | 11:51 PM
BUB20789's Avatar
Default 1999 GMC Sub and 94 Chevy Camaro Engine Swap?
I got to thinking here... I've got a 1999 GMC Suburban with a 5.7 V8 350... and i want to swap that engine out and put it in my 94 Camaro witch currently has a V6 3.4 207.... Could I swap out the engines in these applictionsand transmissions?
Old Dec 23, 2008 | 12:00 PM
crackorn's Avatar
Default RE: 1999 GMC Sub and 94 Chevy Camaro Engine Swap?
I'm sure its possible,some things to think about,oil pan from your burb might not fit in the car,you will need theengine wire harness and computer from the burb,also not sure how that wire harness from the burb will mate up with your car harness.There might also be some differences in transmissions between the burb and the car,you might want to check interchangability on those as well as the drive shaft.Definately a project...good luck!
tlavonda1
Dec 17, 2014 10:30 AM
66impala4dr
May 16, 2011 7:25 PM
JKoe57
Camaro
Jul 30, 2010 12:44 AM
aman721
Feb 3, 2008 4:12 AM
Donald
Oct 23, 2007 7:28 AM
