2016 Camaro
Platform: F-Body & Zeta.
87 iroc will not start
Old Sep 2, 2007 | 3:31 AM
swoosh5_98's Avatar
Default 87 iroc will not start
i have a 87 iroc z28 with 305 tbi. Engine turns over but will not hit a lick. I'm getting fire and fuel ( but not sure if its enough). I replaced fuel filter, fuel pumps hums for a couple of seconds when i turn the key on. Engine turns over just fine. The car ran great before i covered it up and it sat for about a year.When you check the fuel pressure in the fuel rail should it shoot out or just flow out. I had a similar problem with a 4.3L V6 and it was the control module in the distributer. Does my iroc have something similar to that which tells the injectors to fire. Open to all comments and sugestions. thanks
Old Sep 2, 2007 | 11:45 AM
BigBoom360ci's Avatar
Default RE: 87 iroc will not start
Check connections going to the coil for corrosion & if anything has came apart. Maybe the coil itself has gone bad over that period of time sitting also. Just check over everything electrical. Does it have vaccum advance timing? because after a while of sitting sometimes vaccum advanced timing partsin the distributorturn to crap from rust or whatevern starting it can be a pain. As for pressure in the fuel system it should shoot out unless theres a leak.
Old Sep 2, 2007 | 12:32 PM
swoosh5_98's Avatar
I'm getting plenty of fire through all plug wires. The distributor is good as can be inside (no rust). The coil connections are fine and so are the connections to my injectors. My injectors are getting power but they are not spraying gas.
Old Sep 2, 2007 | 4:48 PM
swoosh5_98's Avatar
I had a typing error on my first post. My iroc has a 305 tpi not a tbi. What would kept my injectors from firing. I can get it to crank and run just until itburns the gas i shove down its throat.
Old Sep 5, 2007 | 3:12 PM
The power to your injectors is probably not gettin there so it wont open n spray fuel when needed. Get a volt meter n measure how much electricity thereis even flowing through the wires. If not thing follow the wires back to where the begin so get a wire schematic n do some investigating.
Old Sep 7, 2007 | 1:19 PM
swoosh5_98's Avatar
I know i used a test light on each injector and they have power but u thinkthey may not be getting enough.
Old Sep 10, 2007 | 11:49 AM
Yea they arent gettin enough juice then.
Old Nov 6, 2007 | 9:51 PM
Get a fuel pressure gauge and check the pressure at the fuel rail. Unless your ECU is fried, I doubt that all the injectors would not be getting enuf current to fire. If I remember right, pressure should be about 40-45 psi. Would look it up but sold my service manuals with the car.
Both of my '87 IROCs were 350s. Didn't think they went back to 305s until later like around 1990.
Old Dec 10, 2012 | 7:49 PM
Dominic William Stark's Avatar
first off your injectors only get a trickel of power.itll barely make your test light come on. i just had to replace my injectors in my 305 because i bought the motor out of a junk yard and the car was sitting for year and half. i checked the wiring (ur injector wires are the four wires under the passenger side of the dash that go into the plugs for the comp.there is two plugs.in the middle of each plug there is a pink wire and a pink wire with a black stripe those are what powers them. id just find a set off ebay.they have them used on there for around 60$.if your looking for power there is also a set of 22lbs injectors which is the biggest size you can get for a stock 305 for around 100 and some change.lemme know what you figure out.
Old Dec 18, 2012 | 5:25 PM
rsteele88ta's Avatar
Ive had this exact problem with a tbi 305 CHECK the fuse think its labeled egm but just check them all while your there hope this helps
camaroking
Camaro
Feb 22, 2008 7:05 PM
dk1ben
Camaro
Dec 9, 2007 10:48 PM
xlcrmoemoney
Jul 4, 2007 12:42 PM
Jon
Apr 16, 2007 1:47 PM
stclouder05
Apr 11, 2007 1:09 AM
