2016 Camaro
Platform: F-Body & Zeta.
96 3.8 gets hot. just did head gasket
Old Jul 10, 2011 | 6:32 PM
kreigschnetzer's Avatar
Default 96 3.8 gets hot. just did head gasket
i have just completed a head gasket on my v6 camaro. it seems like it can idle forever in my driveway and not get to operating temp but once we get it on the highway it gets to 240 or so and i pull over before it gets worse. it seems like it happens more when the air is on.... it has a new thermostat, proper coolant mixture, and head gasket. when the air is on the serpantine belt with shift side to side on the idler pully and i can take it off with just my hands... i was wondering if i just need to replace the tensioner to get it to stop overheating or if its something other than that.
Old Jul 10, 2011 | 8:17 PM
kevinkpk's Avatar
Give more info? Even though it is a 5 year old car, have you flushed the cooling system? Is it dexcool, or real coolant?
Old Jul 10, 2011 | 10:28 PM
Chuzz's Avatar
If that's a single belt set up and it's slipping, then, yes, that could be the problem. If there's not enough tension, then the water pump isn't turning fast enough to circulate the coolant through the engine and radiator. Also, did you burp the system when you filled it up? You could have an air pocket. Easiest way to remedy that is to park it on an incline, loosen the radiator cap and run it up to operating temp. This should force all of the air out of the system. Then you just top off the coolant and happy motoring
Old Jul 11, 2011 | 5:02 PM
its a ninety six and i have flushed it about three times. once before the head went out a year ago, once after i finished the head to get the crud out and once recently with dex cool. i used prestone green coolant the other times
Old Jul 11, 2011 | 5:10 PM
i bled it on my driveway which is really inclined. i realized that the heater core was the high point in the cooling system so i tried the incline right away. like i said though the belt does move side to side and is fairly easy to take off. the only thing that makes me doubt or at least not be sure about it being the tensioner is that the power steering works flawlessly and so does the alternator....... i am just kinda tired of dumping money into this thing...
Old Jul 11, 2011 | 7:03 PM
nvm i think i just threw a rod. swwweeeeeeeeeeeettt! thanks anyways though
Old Jul 12, 2011 | 7:34 AM
Chuzz's Avatar
If you threw a rod, you'd know it. Either they turn loose and come out the bottom of the oil pan (if you're lucky) or the side of the block. It would have started hammering like hell if a rod came loose or even if you spun a rod bearing. What makes you think it threw a rod?
Old Jul 13, 2011 | 6:32 PM
loud knocking in what i believe is in the lower half. it wasnt gradual. it was instant
DOBERDEWD
Dec 11, 2011 11:35 PM
Dads Toy
Oct 21, 2011 6:54 AM
gulfcoastjoe
May 4, 2008 12:38 PM
pete90
Oct 4, 2007 6:12 PM
DAN523
Apr 4, 2007 2:22 PM
