2016 Camaro
Platform: F-Body & Zeta.
!994 Chevrolet Camaro 5.7L, Lacks power
Old Jul 26, 2010 | 12:00 AM
2000Impalaspeeder's Avatar
Default !994 Chevrolet Camaro 5.7L, Lacks power
I have a 94 Camaro 5.7L, everytime I start it, and the Temperature rises till full hot, the engine will lag horsepower, I dont why but it just does.. I was thinking if change the Distributor maybe that would fix my Camaro..
Can anyone help me????????
Old Jul 31, 2010 | 11:25 AM
2wd-K5's Avatar
how many km? if lots has the cam or timing chain ever been changed? check the compression in the cylinders, also have you done a tune up to it? i would check these things before buying a new distributor, but if it has over 250k miles a new distributor may be in order, but check the simple free things first
Old Aug 3, 2010 | 10:32 AM
rkuelbs's Avatar
OK, one more reply....just realized these were all from you.
The code 43 is for a knock sensor circuit malfunction. The knock sensor is used to control ignition timing. With a knock sensor malfunction, the PCM is retarding ignition timing way too far, which will cause a lack of power, and will likely cause overheating as well.
Diagnose the DTC 43 and your low power issues should be alleviated.
BigHen
Site Feedback
May 31, 2015 9:06 PM
2000Impalaspeeder
Camaro
13
Jun 1, 2014 2:18 PM
Syris71
Feb 27, 2012 8:31 PM
DJ420
Oct 9, 2009 2:03 PM
Nan-U
May 10, 2009 7:56 PM
