CamaroThis classic Pony Car, the Camaro left the lineup in 2002 and was thought to be gone forever, but is made its long-awaited return in the 2010 model year with a 300 HP V6 and a 426 HP V8 SS
I have a 2015 Camaro v6 RS convertible.
I am trying to find the Cabin Air Filter so I can change it out. All of the YouTubes I look at say it's under the hood on the passenger side, But I don't fine what they are showing.
I'm beginning to think it's behind the glove box. Is this true.
I'd be happy if someone had a video link that shows how to replace it.
Thanks
Frank
Just did this on our 2017...you will have to use some kind of pry bar to drop the glove box as there is no way you can push/pull to clear the insert without some help BUT before you take off the hinge cord,tie a wire tie
or something to the loop end as when you drop the box the cable will fly up and you will have a heck of a time grabbing the end...it is not a hard job but put a towel around your pry bar so you do not scratch the surface of the glove box...it is a good idea to do this as the passenger filter will be pretty dirty...we even found some bird feathers in ours..good luck.
