knocking in motor
knocking in motor
i got a 1984 cmaro, and started hearing knocking in motor, i thought it was loose lifters, but lifters are torqed properly, and still hearing knocking, what should i do?
RE: knocking in motor
Check your valve clearance, if its not that, a severe piston slap could be the cause. Piston slap isa conditiondescribed as worn pistons and/or worn cylinder walls. The piston sdevelop loose motion inside the cylinder bore, thus the slapping/knocking noise.If that is the case,you will need replaceit and hone the cylinder wall.
You need to determine if the noise is from the top of the engine or the bottom. If its the bottom i would think its a crank or rod bearing. If the noise is from the top it may be the lifters, which would sound like a tapping noise.
luckynotsmart
September 18th, 2011 12:45 AM
JVERB97
May 14th, 2009 10:22 PM
jherkel
14
May 7th, 2009 1:38 AM
