2016 Camaro
Platform: F-Body & Zeta.
knocking in motor
Old Feb 28, 2008 | 2:44 PM
yongcees's Avatar
Default knocking in motor
i got a 1984 cmaro, and started hearing knocking in motor, i thought it was loose lifters, but lifters are torqed properly, and still hearing knocking, what should i do?
Old Feb 28, 2008 | 10:54 PM
EvansBlue's Avatar
Default RE: knocking in motor
Check your valve clearance, if its not that, a severe piston slap could be the cause. Piston slap isa conditiondescribed as worn pistons and/or worn cylinder walls. The piston sdevelop loose motion inside the cylinder bore, thus the slapping/knocking noise.If that is the case,you will need replaceit and hone the cylinder wall.
Old Feb 29, 2008 | 12:29 AM
yongcees's Avatar
i believe that either my lifters are no good, or i may have threw a rod. what u think
Old Mar 4, 2008 | 8:55 PM
ktm521's Avatar
You need to determine if the noise is from the top of the engine or the bottom. If its the bottom i would think its a crank or rod bearing. If the noise is from the top it may be the lifters, which would sound like a tapping noise.
drucker13
Feb 16, 2012 8:09 AM
luckynotsmart
Sep 18, 2011 12:45 AM
poormansdvd
Oct 3, 2010 10:58 AM
JVERB97
May 14, 2009 10:22 PM
jherkel
14
May 7, 2009 1:38 AM
