2016 Camaro
Platform: F-Body & Zeta.
P2227 Code After Cold Air Intake
Old Nov 29, 2023 | 1:20 PM
Brightonb34's Avatar
Default P2227 Code After Cold Air Intake
I just installed a cold air intake on a friend of mine’s car, and when we fired it up, the CEL came on and the baro sensor code is what came back. The first one was a generic one and the second said the reading was high. I popped the hood, and the clip was loose, so I popped it back in making sure it was tight. Boom problem solved it started with no check engine lights, and she just texted me saying she has another light on the dash. Is there a way to remedy this without going back to factory intake? P227 code on 2018 2.0T Camaro
Old Nov 29, 2023 | 2:49 PM
scan the car for trouble codes , and post what they are.
Also, you need to post the vehicle info please.
Originally Posted by Brightonb34
Is there a way to remedy this with out going back to factory intake?
if you don't tune the car for it, it's not doing much anyway
Old Nov 29, 2023 | 7:24 PM
Updated post
Old Nov 29, 2023 | 7:50 PM
try the troubleshooting steps here:
https://www.obd-codes.com/P2227
Old Dec 28, 2024 | 2:12 PM
Swan01's Avatar
I want to say most “cold air intakes” are actually hot air intakes. The whole purpose of cold engine inlet air is the science behind it. Colder air is more oxygen dense. More oxygen density paired with more fuel will (generally) create more power.
when you put an engine air inlet in a hot engine bay, it’s helping nothing and often losing power unless you have the hood completely removed. People just like the sound because you often remove some sort of silencer or resonator for the intake pipe.
furthermore, turbocharged engines will receive even less of a benefit with these so called cold air intakes because while they do rely on cold air supply from the turbo inlet pipe, they more so rely on an efficient intercooler to cool charge air that’s actually entering the intake manifold.
Old Nov 30, 2025 | 10:16 PM
rores's Avatar
I just installed a cold air intake on a friend of mine’s car, and when we fired it up, the CEL came on, and the baro sensor code came back. The first one was generic and the second said the reading was high. I popped the hood and found the clip was loose, so I snapped it back in securely. Boom, problem solved, things were looking good, just like searching for Apartments for sale in Athens when you finally find a great option, it started with no check engine lights, but now she just texted saying another light came on the dash. Is there a way to remedy this without going back to the factory intake? P227 code on a 2018 2.0T Camaro.
Yes, you can fix it without going back to the factory intake. On the 2018 Camaro 2.0T, P227 happens because the cold-air intake changes airflow and the ECM calculates barometric pressure from the MAF sensor. Reseating the loose connector helped, but contamination on the MAF, a small intake leak, or a new tube with a different diameter from stock can still cause the reading to be too high. Clean the MAF with proper MAF cleaner, double-check all clamps and hoses, then reset the ECM by disconnecting the battery for 10 to 15 minutes. If the code keeps coming back after that, the intake simply needs a basic tune to recalibrate the MAF and eliminate the CEL, with no need to reinstall the stock intake.
Martin Ruiz
2014 - 2018 (GMT-K2)
May 5, 2021 8:48 AM
FearTheCavalier
May 2, 2020 8:25 PM
Rafael Skierkowski
Mar 17, 2019 6:56 PM
DON JUAN Huff
Jan 16, 2018 8:10 AM
313hitman
Camaro
Apr 21, 2008 9:13 AM
