Shaking Steering Wheel
Shaking steering wheel for Camaro
The two most frequent causes of a shaky steering wheel are either warped brake rotors, which will cause your steering wheel to shake when you brake, or unbalanced tires, which will cause your steering wheel to shake when driving at high speeds.
There are other possible causes of a shaking steering wheel though. By thinking critically about how and when your steering wheel shakes, you can narrow down what the issue may be. Having a shaking steering wheel is incredibly frustrating, and it’s usually a symptom of a larger issue. By starting to figure out what the problem might be and preemptively looking for a solution, you’re already doing a great job of preventing a major mechanical malfunction.
