Take your driving to a whole new level with Lowering Coilover Kit: CARiD Top Picks
Former Sponsor
While the factory suspension is designed to meet the needs of the masses, aftermarket performance suspensions are created for enthusiasts who are after improved responsiveness, handling, acceleration, and braking. Lowering kits provide dramatic improvements in both the look and performance of your Camaro.
As a result, you'll get an aggressive lowered stance along with stiffness for better cornering and braking ability. Whether you are building a high-performance vehicle, a show car, or just want to give your Chevy Camaro a performance edge, a lowered suspension is a must-have modification.
Today we are here to introduce the best two aftermarket options, popular among CARiD customers. Made by Bilstein and Yellow Speed Racing, they allow you to customize the height of your ride and improve both a vehicle´s performance and appearance.
Bilstein® - 0.4"-1.2" x 0.4"-1.2" B14 Series Front and Rear Lowering Coilover Kit
https://www.carid.com/bilstein/front...47-280502.html
Features:
Yellow Speed Racing® - 0"-3" x 0"-3" Dynamic Pro Sport™ Front and Rear Lowering Coilover Kit
https://www.carid.com/yellow-speed-r...cv-dps007.html
Features:
Features:
- Monotube internal design
- Threaded body adjustable range of 20 mm at both axles, while installed
- Road-tested by BILSTEIN under motor sports conditions and fine-tuned
- Spring plates and lock nuts made from a special aluminum alloy
- Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
- Round threads for ease of adjustment
- Quality sport springs made from highly durable material
- BILSTEIN gas pressure technology
- BILSTEIN mono-tube/Upside-Down technology, made in Germany
- German TÜV certificate
Features:
- 33-Way Dampening Adjustable
- Newly Improved Rear Dampening Adjustment Method
- Spring Bearing Top
- Monotube Internal Design
- Pillow Ball Upper Mount With Adjustable Camber Plate
- High Rigidity Steel Spring
- Adjustable Spring Seat
- Full Length Adjustable
- Lower Locking Collar
- Developed Damping Oil
- Aluminum Upper Mount
- Wave Alloy Steel Thrust Washer
