2016 Camaro
Platform: F-Body & Zeta.
V6 Whistling noise
Old Oct 5, 2017 | 9:56 AM
whale's Avatar
Default V6 Whistling noise
My 2013 V6 Camaro makes a whistle noise at high speed while accelerating. Diminishes on closed throttle. Coming from under the hood. Any ideas?
Old Oct 6, 2017 | 9:44 AM
If there is no performance degradation then I would check all of the joints and gaskets in the intake air flow path.
Old Oct 6, 2017 | 12:52 PM
whale's Avatar
Sounds like a good place to start. I am puzzled because the noise starts at 85-90mph on a WOT. Starts to go away on a closed Throttle while costing. You would think a vacuum leak would be the other way around..
Thanks
Old Oct 6, 2017 | 2:07 PM
I ruled out a vacuum leak since there is little or no vacuum at WOT.
