Platform: B-Body
1991 Caprice
Old Mar 20, 2021 | 11:13 AM
Ed Reynolds's Avatar
Default 1991 Caprice
I own a 1991 Caprice. The car sat in a warehouse for many years. It would not start and so I pulled the gas tank. The fuel pump assembly was very rusty and the f/p would not run. I replaced the f/p assembly with new parts and had the tank cleaned.. The f/p will only run if I connect it directly to a second battery but the engine will still not run. The engine will only run (momentarily) if I squirt some ether into the carburetor. I disconnected the fuel tubes at the carburetor and tried to blow air into the other end of the tube at the fuel filter. I could not blow any air into the tube. So, there is no gas going from the f/p to the engine even when a second battery is used to power the f/p and I can hear it running. There is also no current going to the f/p from the car's battery. I have also replaced the f/p relay and the f/p fuse.
riding4eight
Jul 29, 2019 7:44 AM
cogs38
Apr 14, 2017 11:10 PM
66caprice327
May 5, 2014 3:04 PM
91caprice103
Oct 14, 2012 1:04 PM
