Platform: B-Body
1991 Caprice 5.0L A/C work
Old Mar 30, 2013 | 8:09 AM
WyrTwister's Avatar
Default 1991 Caprice 5.0L A/C work
My late father's Caprice had been parked for 10-15 years . It is obvious from the oily dirt around the A/C compressor , that the freon ( and much of the oil ) has leaked out .
If I just vacuum it down , check for leaks , recharge with freon and oil , what are the chances the seal will be OK , once it gets wetted / lubricated with oil ?
To replace the seal , I am pretty sure I can remove the clutch parts . What tooling is need to remove the old seal and replace with a new seal ?
I am guessing I need to pour the old mineral oil out of it & install PAG oil in it and a new accumulator ? I think there are several types of PAG oil ? How do I find out which type to use ? How much ?
I have read to put 1/2 the required amount in the compresses and 1/2 in the accumulator ?
I will vacuum it down , hard , maybe over night & then let it set for a couple of hours & check for loss of vacuum .
God bless
Wyr
Old Apr 2, 2013 | 6:16 AM
WyrTwister's Avatar
I have found a seal kit at O'Reilly Auto Parts . Very helpful .
I think I will nee to use ester oil .
I found out this is a R4 compressor .
God bless
Wyr
Tennesseestorms
Feb 14, 2010 4:56 PM
300winchester
Jan 8, 2010 10:36 AM
bocabill
Dec 1, 2009 4:41 PM
Fast 82
Jun 5, 2008 8:13 AM
sidewayzpimpin
Jun 12, 2007 6:40 PM
