Platform: B-Body
1991 caprice alarm installation Help
Old Oct 23, 2010 | 10:33 AM
Caprice Runner's Avatar
Default 1991 caprice alarm installation Help
I was wanting to know if any one has installed a Viper 5701 or similar remote start and alarm combo on a 91 chevy caprice if so can you look and verify where each wire is suppose to go and let me know if i need to make any changes. I just want to verify everything before installing.
Primary harness (H1), 12-pin connector
H1/1
RED/WHITE (-) 200mA TRUNK RELEASE OUTPUT-----------Black @ Release switch
H1/2 RED (+)12v CONSTANT INPUT-------------------------------Red @ Ignition harness
H1/3
BROWN (+) SIREN OUTPUT----------------------------------Red @ Siren
H1/4
WHITE/BROWNLIGHT FLASH ISOLATION WIRE------------- Not Used
H1/5
BLACK (-) CHASSIS GROUND--------------------------------Grounded
H1/6
VIOLET (+) DOOR TRIGGER INPUT--------------------------White @ underdash light
H1/7
BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT-------------Not used
H1/8
GREEN (-) DOOR TRIGGER INPUT----------------------------Not Used
H1/9
BLACK/WHITE (-) 200mA DOME LIGHT OUTPUT------------White @ underdash light
H1/10
WHITE/BLUE (-) REMOTE START/ TURBO ------------------Not sure where it go
H1/11
WHITE PARKING LIGHT OUTPUT----------------------------Brown @ Headlight Switch
H1/12 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT------Not sure where it goes
Door lock harness, 3-pin connector
BLUE (+) LOCK -------------------------------------Light Blue(+) @ driver kick door
EMPTY NOT USED
3 GREEN (-) UNLOCK ---------------------------------Black(+)@ driver kick door
Heavy gauge remote start, (H3)
10-pin connector
PINK (+) IGNITION 1 INPUT/OUTPUT-----------------------------Pink(+) @ Ignition Harn.
RED/WHITE (30A) FUSED IGNITION 2 / FLEX RELAY INPUT 87------Red @ Ignition Harn.
ORANGE ACCESSORY OUTPUT------------------------------------Orange @ Ignition Harn.
4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER)-----Purple @ Ignition Harn.
GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER)---------Purple @ Ignition Harn.
RED (+) FUSED (30A) IGNITION 1 INPUT--------------------------Red @ Ignition Harn.
PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT------------Pink(+) @ Ignition Harn.
PINK/BLACK FLEX RELAY INPUT (if required) of ----------------Pink(+) @ Ignition Harn.
RED/BLACK FUSED (30A) ACCESSORY/STARTER INPUT----------Red @ Ignition Harn.
10 N/C N/C
Remote start input, 5-pin connector
BLACK/WHITE (-) NEUTRAL SAFETY SWITCH INPUT----------Grounded
VIOLET/WHITE TACHOMETER INPUT WIRE--------------------Violet/White @ Ignition Coil
BROWN (+) BRAKE SHUTDOWN WIRE--------------------------White @ Break Switch
GRAY N/O or N/C (-) HOOD PIN SWITCH INPUT, ZONE 6------Red @ hood pin
5 BLUE/WHITE (-) 200 mA 2ND/REAR DEFOGGER-------Orange/Black @ defroster switch
Cuco
49
Jan 27, 2020 6:50 PM
puffinx7
Dec 5, 2013 4:13 PM
knarva
Apr 13, 2013 7:23 AM
biglg
May 15, 2007 11:09 PM
