Platform: B-Body
87 Caprice no brake pedal
Old Oct 20, 2019 | 1:56 AM
Deerdog's Avatar
Default 87 Caprice no brake pedal
My friend tryed to move his car and suddenly had no brakes , no pedal , went to the floor. I'm trying to fix it for him , but not Shure how to find the problem. I found a rotten vacuum line that was leaking badly. I replaced it. Still no brake pedal pressure.
Brake fluid looks full. I'm not Shure what to look for next. Please Help !
This problem was sudden , no warning after sitting for 2 weeks.
Old Oct 20, 2019 | 3:11 AM
oilcanhenry's Avatar
Well, if there was one bad vacuum line, there might, not positive, be lots of other issues with a vehicle that is 32 years old. Could easily be a bad master cylinder or a bad slave cylinder if it has any drum brakes, or a bad caliper piston with disk brakes, or a bad brake line somewhere.If you can't easily see anything wrong, then it's likely that there is air in the system, and the whole brake system might need to be flushed out and the brake fluid replaced.
Older vehicles tend to need to have more things changed out, then newer ones due to age and the environmental conditions the vehicle has been running in for it's lifetime, and of course the maintenance of the vehicle by the owners.
Old Oct 20, 2019 | 6:10 AM
Deerdog's Avatar
Default Caprice brake problem
WOW ! Thank You for your response . That's Alot more than I was expecting , to much for me to handle.
Old Oct 20, 2019 | 3:13 PM
Thanks, Deerdog. We try very hard to diagnose vehicle issues here, even non-GM vehicles, although most of us are Chevrolet "Bow-tie" lovers.
Old Oct 23, 2019 | 9:49 PM
Irish_alley's Avatar
I'm here for the party
double check your brake fluid level. on my 94 with the jb3 brake system it has the plastic reservoir. its dirty to the point even when completely emptied it still looks full till you try to stick your finger in the hole. my brother called me one day when using it and said the same thing you did. "pedal goes straight to the floor and the reservoir is full" the truck had leaking wheel cylinders that would empty the reservoir when it sat for too long.
Old Oct 23, 2019 | 11:27 PM
Deerdog's Avatar
Thank You I will check it out
joe0072
Sep 23, 2017 10:41 AM
MDBowtie
Sep 4, 2016 12:17 PM
MYOBtoday
Mar 19, 2014 2:06 PM
David Ruggles
May 15, 2013 9:32 PM
blj0hnst0n
Apr 17, 2013 1:55 AM
