Platform: B-Body
91 Caprice won't start!
Old Feb 19, 2012 | 9:08 PM
Julius Collier's Avatar
Default 91 Caprice won't start!
I have replace the fuel pump, fuel filter, and battery. It cranks, and if you pour has in the top it starts. It is a 350 motor, best guess is that it is a throttle body. Could someone tell me why it isn't getting gas.
Old Oct 13, 2012 | 9:27 AM
91chevcaprice's Avatar
Hi Julius I have the same vehicle 5.7 and mine won't start either. If I spray starting fluid in carburator it will start and run fine. I have replaced the fuel filter. Some times it starts fine and some times it acts like this. If I ever figure out my problem I will write you back and tell you.
Old Jan 20, 2013 | 6:24 AM
WyrTwister's Avatar
Make sure you are getting gas to the throttle body . Loosen the line a tad and have some one turn on the ignition .
Make sure the wiring to the injectors is OK .
Think there is a fuel pressure regulator ? Excess fuel is returned to the tank ? Try to figure out if the regulator is working ?
Any loose wiring / sensors or vacuum lines od vacuum gadgets ?
Get a Haynes or Chilton book .
I can go online to our local library and get some Chilton info .
ChiltonLibrary.com - Authorization Issue
Do not know if this link will work for you ?
God bless
Wyr
ajayz2006
Sep 1, 2010 5:23 PM
pveco@q.com
Jun 7, 2010 1:00 AM
bocabill
Dec 1, 2009 4:41 PM
bracca
Jul 12, 2009 6:14 PM
Kurtleathers
Jun 2, 2009 6:55 PM
