Platform: B-Body
AC canister vacuum?
Old May 15, 2021 | 6:44 AM
70caprice's Avatar
Default AC canister vacuum?
Fat chance I’ll get an answer but here goes: I have a 1970 Caprice with a 350 and air conditioning. It has a vacuum canister to run the dashboard selector for heat or cool. Wondering if anyone knows the minimum vacuum needed to run this control as I am modifying the engine which will drop the vacuum to 15 inches. Will I need a vacuum assisted pump?
Old May 15, 2021 | 3:34 PM
kevinkpk's Avatar
15" should be fine, that canister is a volumn bottle.
Old May 23, 2021 | 8:51 PM
jimmyblue's Avatar
The idea is that the vacuum reservior will be drawn down
to "peak vacuum" (checkball feed) so that you have useful
vacuum reserve for next braking.
If you -never- get above 15"Hg vaccum then a pump might
be handy. But cams only depress low-RPM vacuum and
normal driving may be enough to keep the reservoir
"charged".
mallisonb
Mar 17, 2013 12:44 AM
clintsy
Jun 23, 2012 11:03 PM
RakerBill
Nov 19, 2010 3:14 AM
mbu
Feb 12, 2010 10:14 PM
BISCAYNE
Jun 6, 2006 1:39 PM
