Platform: B-Body
Crankshaft position sensor question
Old Aug 3, 2020 | 11:19 PM
williajr3's Avatar
Default Crankshaft position sensor question
I have a 96 Chevy Caprice 4.3 V8 and I was wondering if I would have to do a crankshaft position sensor relearn when I replace the crankshaft position sensor...
Old Aug 4, 2020 | 7:03 AM
Welcome from Florida. I have replaced several of them and did not have to do anything. Replaced a bad one and it started right up and ran good.
Old Aug 4, 2020 | 10:28 AM
williajr3's Avatar
Yea I changed it and its starting right up, but the code keeps popping back up.. Would you know why?
Old Aug 4, 2020 | 11:17 AM
What is the code? Do the wires going to the sensor look to be in good shape?
Old Aug 5, 2020 | 7:32 AM
williajr3's Avatar
The code is p0336 and p0335.
I have to look at the wires to make sure they are good.
Old Nov 12, 2020 | 12:43 AM
jimmyblue's Avatar
You maybe need to look for "the codes behind the codes".
At least in the LS1 family, CKP relearn is inhibited by quite
a few other DTCs. It's also pretty difficult to do the forced learn
(I had maybe 1 in 10 success rate when I was tuning), the
sequence was pretty fussy).
Crank relearn should sort itself in the drive cycle and only
some other problem, or a driving routine that doesn't hit
all the criteria, should make the forced relearn necessary
(provided you're willing to wait).
wizzardchick
Aug 21, 2017 2:48 PM
Bg950762
May 15, 2017 6:29 PM
Bg950762
May 15, 2017 5:43 PM
Phill S.
Jan 1, 2013 3:10 AM
perezst
Jun 2, 2010 10:52 AM
