Platform: B-Body
Engine v8 305 gen1 with quadrajet ... HELP
Old Oct 30, 2017 | 12:28 PM
Enzo305's Avatar
Default Engine v8 305 gen1 with quadrajet ... HELP
Hey all,
i own a 88 caprice classic brougham LS with a 305 v8 1st generation engine with a Rochester quadrajet carb on top
i recently overhauled the carb bought a new kit for it and cleaned it. Not sure if i well adjusted the mixture (watched over a ton of youtube links and DIYs...)or else but the engine is now weak and runs like a v6 not a v8 pfffff... Tuned the mixture front screws till I got the high idle sweet spot for both screws then adjusted the idle speed screw ... I can say there is no more hesitation no more backfiring and a noticeable gas mileage .. BUTTTT ...runs like grandma... The TV cable is adjusted.. What could be the problem? It had massive power before when the carb was in a ****ty conditions loooool... Any help is appreciated thanks.
Old Oct 30, 2017 | 3:28 PM
kevinkpk's Avatar
Did you jack with the float?
Old Oct 30, 2017 | 3:29 PM
kevinkpk's Avatar
Also, is the inline filter new/replaced, and in correct? Did you replace the accelerator pump with one in the kit, if so, was the spring the same as the original (length, ect)?
Old Oct 30, 2017 | 3:39 PM
Enzo305's Avatar
Float is OK and tested the power valve too..all is OK ... Well I noticed that my TV cable adjustment "button" isn't working ... Might this affect performance? When I rev the engine it roars like a beast. It when on road its grandma lol .. Ow and does the EGR has anything to do with my problem? I'll consider cleaning it too.
Old Oct 30, 2017 | 3:42 PM
Enzo305's Avatar
About the inline filter ...well... When I removed the old one to replace it the spring jumped and I lost it ... I feel dumb saying that lol.. But I kept the filter with no spring until I buy another one...should this affect anything?
Old Oct 30, 2017 | 3:44 PM
Enzo305's Avatar
i replaced everything that came in the new carb kit
Old Oct 30, 2017 | 4:29 PM
kevinkpk's Avatar
You should replace the filter spring as that keeps the gasket on the filter to the body sealed. The kick down cable probably is your issue
Old Nov 3, 2017 | 7:53 AM
Enzo305's Avatar
Cool
so after a long day on wednesday, i removed the carb and found that my secondary flaps aren't opening and there was a tiny carbon piece sitting under the float needle.. so cleaned everything with carb cleaner and pressure air then mounted the carb, tuned it again,,,,,,,,, and voilaaaa .. i can even hear the jets whistle like a turbo haha .. what a great relief and happiness i felt and now my ride is now more powerfull.
