Platform: B-Body
Need help. Power window problems
Old Feb 19, 2010 | 4:33 PM
DADS81CAPRICE's Avatar
Default Need help. Power window problems
Ok, so here is the deal. My dad has a 1981 Caprice Classic. Meticulously maintained and in great condition for it's age. The problem is only the drivers side rear window will operate. It started as an intermitent problem, now it is all the time and he has one stuck in the down position and can't take it anywhere. Any suggestions would be greatly appreciated.
Old Feb 20, 2010 | 11:15 PM
s34n's Avatar
probably time for a new window motor
Old Feb 20, 2010 | 11:47 PM
nauticstar87's Avatar
Window motor, check the fuses, and all the connections.
Old Feb 21, 2010 | 12:40 PM
Default Window problems
Originally Posted by nauticstar87
window motor, check the fuses, and all the connections.
i don't beleive that it is the motor,or the fuses as one window works and the other three don't. I checked the under-dash fuse and it was fine. Any other ideas ? Thank you for your comments.
Old Feb 25, 2010 | 8:48 PM
capriceus's Avatar
Hi,
Sorry I don`t have a real solution, but I do sympathize with him, as I have the same type problems. On my 1992 Caprice, every one of my windows don`t work properly any more. I managed to get them ALL UP and simply do not put them down any more. I have air conditioning for the summer and manage OK.
A garage mechanic told me $400 per window and he can put new motors , rollers, etc. in. No thanks ! I`ll drive it as it is, and buy a new car , probably in a couple years. I hate electric windows !
Old Mar 4, 2010 | 12:32 AM
mobileinstaller's Avatar
fastest and easiest way to check the motor is un plug the 2 pin connector on the motor and apply 12 volts to one pin and ground to another if that works then the problem is in the switch or the wiring and normaly the problem is in the switch try that and let me know how it turns out. also don't matter which pin you use as one way the window will go up and if you reverse them then the window will go back down.
Old May 28, 2010 | 4:26 AM
KikaSmile's Avatar
Default Need help Power window problems
Yes, I realize this model is definitely flawed, and no, I do not believe in this model.
But just for arguments sake, come anyone here figure out some speeds for me?
justin69
Feb 28, 2015 2:54 PM
davbell22602
Mar 10, 2010 8:36 PM
lmiskowicz
Nov 21, 2007 9:02 AM
