Platform: B-Body
Oil Problem
Old Apr 11, 2007 | 12:06 AM
chevyfam's Avatar
Default Oil Problem
1991 Chevy Caprice Classic w/ 305... Started it up this morning and oil started leaking out near the oil filter... Initially I thought maybe the oil change place put on the wrong filter, but after changing the filter, and filled the oil back up, started the car up and it appears the oil pressure is causing the seal on the filter to burst and the oil came back out....
Anyone experienced this??? Please help it seams like the oil pump has to much pressure..... What could make this happen it was running fine last night.... Looking for help , thanks chevy owners in advance....
Old Apr 28, 2007 | 11:15 PM
countilaw's Avatar
Default RE: Oil Problem
I've seen this happen before. It is usually a faulty oil filter. The filter has a oil pressure release valve inside. This is so that if thefilter cloggs up, the oil by passesthe filter and continues to circulate through the engine. If this thing sticks, it will blow the oil seal on the filter.
trolea1234
Mar 3, 2009 10:58 AM
Toby T
Mar 14, 2008 5:16 PM
Big D
Jan 10, 2008 6:53 PM
trush
Jan 1, 2008 9:27 PM
larry_chip
Apr 24, 2007 11:46 AM
