rear seat removal help needed
remove rear seat
Hi,
Im not sure if it is still like in the old chevy's.
In the old chevrolets you have to push the seating down and backwards.
In my old chevy's they have NEVER been bolted or fastened with screws, they are just "clicked" behind some hinges.
Hope it helps.
Later,
Alphons
Hope it helps.
Later,
Alphons
To remove the rear seat, pull up on the bottom, it's clipped in two spots, a hard pull will release the bottom. The back is a different problem. The seat belts have to be removed. They are held in place by star bolts. I spent $8.00 for the right star key at Ace. after the bots are removed, lift up on the rear seat and the clips slide down and off you go.
gamecock
December 31st, 2012 6:14 PM
