Platform: B-Body
Rebuild or replace?
Old Jun 12, 2022 | 8:51 PM
Bigjad's Avatar
Default Rebuild or replace?
I’m starting to restore my 1975 Chevy Caprice Classic convertible. It’s been sitting in my fathers garage since 1994/95. I started out by pulling the radiator to replace because it was completely dry and rusted through out and when I pulled the thermostat housing, there was no thermostat but a lot of rust and crap.( see pictures) The lower radiator hose had rusted debris in it and the inside of the water pump where it was attached was corroded. When I try and turn the crankshaft pulley with a socket, it doesn’t move. So before I bother to continue pulling the intake and heads should I assume that the engine is seized and dead? Would it make sense to try and have it completely rebuilt( it’s a 400 small block) or should I just drop in a new full dressed crate engine?
Thermostat should be here
Water pump
thermostat should be here
Old Jun 12, 2022 | 9:42 PM
oilcanhenry's Avatar
I'd drop some kind of motor in there. The corrosion and internal damage is too bad for a rebuild, IMO.
Old Jun 16, 2022 | 10:32 PM
jimmyblue's Avatar
No telling what the bores look like but sounds like a history
of poor maintenance.
Depending on how your "modern motor" skills are, might suggest
something like pulling a 6.0L LQ9/4L80E with harness out of a
2500HD pickup wreck. I just went through a 700R4 swap that
still isn't right, and shoulda sold the mildly built 400 instead since
I have the tuning tools for many GM vehicles.
L84sky
Dec 30, 2020 5:04 PM
JimHeide
Nov 28, 2017 11:27 PM
Ben C.
Jan 23, 2017 12:38 PM
leviathan907
Mar 12, 2012 7:31 PM
c-clayton@msn.com
Feb 27, 2009 10:56 PM
