Chevrolet Malibu
2004 Malibu Maxx needs thermostat replaced
Old Feb 23, 2009 | 10:29 PM
c-clayton@msn.com's Avatar
Default 2004 Malibu Maxx needs thermostat replaced
Can anybody provide service procedure/location to swap out the thermostat?
Old Feb 24, 2009 | 5:42 PM
shawnvw's Avatar
Banned
what motor do you have?
Old Feb 24, 2009 | 9:04 PM
Maxx LS with 3.5L.
Old Feb 25, 2009 | 4:18 PM
shawnvw's Avatar
Banned
Removal Procedure
  1. Remove the air cleaner intake duct. Refer to Air Cleaner Inlet Duct Replacement in Engine Controls - 3.5L.
  2. Partially drain the cooling system. Refer to Cooling System Draining and Filling .
  3. Reposition the hose clamp from the water outlet housing.
  4. Remove the radiator inlet hose from the water outlet housing.
  5. Remove the water outlet housing bolts.
  6. Remove the water outlet housing.
  7. Remove the thermostat.
  8. Clean and inspect the water outlet housing gasket mating surfaces.
Tighten
Tighten the bolts to 25 N·m (18 lb ft).
Old Feb 26, 2009 | 6:55 AM
thermodix's Avatar
I think you may try to use to look at here guys, this may help you a little guys... http://www.autopartswarehouse.com/sh...vy/malibu.html
Hope this help you a little guys....
_________________
Thermostat
Old Feb 27, 2009 | 10:56 PM
Is the coolant drain easily accessible? I haven't crawled under the chassis to see how/where it is.
Confused Chevy Owner
Apr 21, 2014 9:07 PM
clayhead1989
Oct 5, 2009 1:49 PM
daced
Jul 21, 2009 9:28 PM
Mr.K
Dec 18, 2008 6:00 AM
gargamel343
Mar 14, 2007 12:58 PM
